Keyframe indipendent from build in/out
COW Forums : Apple Motion
Francesco Benciolini
on Nov 26, 2014 at 11:16:03 am
Hi, i'm trying to create a title for FCPX using motion5, the title has to be a gear rotating at 1 turn every 5 seconds, sliding in; the title appears, stays in place, then disapears and the gear slides out, i'm using build in/out markers, but the rotation speed is affected by the length of the title, how can i make it a constant? i tried to create a video of the gear rotating and then animating it but it remaps the video time.
Mark Spencer
Re: Keyframe indipendent from build in/out
on Nov 26, 2014 at 2:45:21 pm
You need to use a Loop marker at the end instead of Build markers.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
on Nov 26, 2014 at 6:31:10 pm
but in this way i loose the slide out
