Behavior Goes Beyond the End of the Timeline
COW Forums : Apple Motion
Ryan Shepard
on Nov 20, 2014 at 3:49:09 pm
What is the best way to handle behaviors that extend beyond the end of the timeline like the two Fade In/Fade Out behaviors in this screen shot? When I added the behavior the layers were too long. I shortened the layers by selecting them and choosing "Split" from the Edit menu as this is the best way I know to shorten a layer that extends past the end of the timeline. The problem is that the behaviors didn't shrink with the layers. Thanks for your help!
Eddie Cook
Re: Behavior Goes Beyond the End of the Timeline
on Nov 20, 2014 at 11:40:49 pm
Move the playhead to where you want the behavior to end
Select the behavior
hit o
This sets the outpoint of the behavior (and any other object type) to where the playhead is.
You can also also use it via the Mark Out command found in the Mark menu.
You can also set the timing for any object in the Inspector via it's Timing parameters in its Properties pane.
