PDFs not Vectorized when in Replicator
COW Forums : Apple Motion
Lorenzo Vidali
on Sep 16, 2014 at 2:08:48 am
Hi Everyone,
I am using a pdf in motion that scales just fine until I hit the "L" key to create a replicator from it. Then it the individual cells behave as if it they have fixed resolution.
Any ideas?
Robin S. Kurz
Re: PDFs not Vectorized when in Replicator
on Sep 16, 2014 at 2:41:55 pm
Unfortunately, that's a bug. You'll have to make a rastered image of the file and use that.
Lorenzo Vidali
on Sep 17, 2014 at 2:00:49 am
One for the feedback page I guess.
Thanks for your help.
Mark Spencer
on Sep 17, 2014 at 2:16:57 am
It's not a bug it a function of the order of operations. A vector object has to be rasterized in order to be replicated. Same with Emitters.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Robin S. Kurz
on Sep 17, 2014 at 11:41:37 am
[Mark Spencer] "It's not a bug it a function of the order of operations. "
Well, yes and no. Let's say that that's to be expected *technically*, only *practically* it shouldn't be happening. It should be possible to continuously rasterize in a case like that. And when I showed this to the Motion guys a while back when I came across it myself, they didn't seem to think that it was right either and wanted to look into it.
Luke Jones
on Sep 25, 2014 at 3:13:55 am
Would this work for you? Select the pdf in the media tab and turn off "fixed resolution". Then for the replicator, change it to 3D.
Lorenzo Vidali
on Sep 25, 2014 at 3:16:44 am
That last part "Change the replicator to 3D" was the key!
Now it vectorizes perfectly.
Important note to others, you still need to uncheck "fixed resolution" in the media pane of the inspector.
Thank you!
