Trailing stars
COW Forums : Apple Motion
Michael Campione
Trailing stars
on Aug 26, 2014 at 10:47:50 pm
Hi All,
Is there a way to duplicate the Paramont stars movement in Motion 5? Or if you could steer me to a good tutorial. Having a heck of a time with it. I've seen a couple of tutorials in after effects so there must be something in Motion.
Thanks much.
Michael
Mark Spencer
Re: Trailing stars
on Aug 26, 2014 at 11:02:50 pm
I'd use a replicator and animate the stars along a motion path in 3D.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Michael Campione
Re: Trailing stars
on Aug 27, 2014 at 1:11:38 am
Thanks Mark
Sad to say I haven't spent much time with the replicators. Doing simple stuff but need to jump to the next level.
It makes sense what your saying especially since I'm trying to do it by building each star and each with its own B-Spline. I don't see it ending well. lol
Do I use like the Line Segment replicator and modify it? There doesn't seem to be a generic one anywhere.
or I'm not looking hard enough.
Michael
Michael Campione
Re: Trailing stars
on Aug 27, 2014 at 1:43:00 am
Ah! I think I figured it out.
Didn't see the little replicator button way down in the bottom corner.
Mark Spencer
Re: Trailing stars
on Aug 27, 2014 at 1:44:14 am
There are existing star shapes in the Library you can use. You replicate them to Geometry and put the motion path in the well. Doing just the semi-circle is relatively easy. If you want to fly them in from the foreground, twisting through 3D space, that takes some more effort and knowledge.
Mark Spencer
Michael Campione
Re: Trailing stars
on Aug 27, 2014 at 2:58:35 am
Mark I really appreciate you getting me this far.
So here's where I am.
I did use the star shape.
Replicator:
set to Geometry
Shape source well is empty
Points set to 15 (stars)
They're piled on top of each other.
Motion path:
Path Shape is set to open spline (because that seems to be the only thing I can shape the path with)
Shape Type B-Spline
Problem: Stars are stacked on top of one another and cannot drag Motion Path to Replicator well.
Stars follow path as a clump and can't seem to separate them
Oddly enough the 3D space and drawing the B-Spline path I don't seem to be having any trouble with making one star perform the way I want. Its getting the 15 to follow after one another.
Michael
Michael Campione
Re: Trailing stars
on Aug 27, 2014 at 9:51:45 pm
I almost have this nailed.
In addition to my last post, I added a sequential replicator (something I had to really search for)
That gave me the trailing stars. However,
The stars build out to 15 then end as one star at the end of the motion path.
Heres how far I got and the problem.
Is there a way to control the parameter of each individual star? i.e. Each yellow stars need to stop on their respective black stars and not back into one star (object). In addition each has to rotate slightly into position.
If this is something I have to do by individually attach a motion path to each star then so be it. Just thought there might be a better way.
Again thanks for any help
Mark Spencer
Re: Trailing stars
on Aug 27, 2014 at 10:47:35 pm
I'm not sure the sequence replicator is going to get you there.
The best way to approach this is going to be to use a text layer instead of a shape or graphic. By using Edit > Special Characters you can insert a star symbol and then copy-paste it.
The advantage of a text layer is that you can set the Type (in the Layout pane), then set the Path to Geometry, then you can keyframe the Offset parameter to animate the series of characters (stars) along this Motion path, and they keep their relative positions.
Mark Spencer
Michael Campione
Re: Trailing stars
on Aug 28, 2014 at 9:25:39 pm
Hi Mark
I am going to try the text layer when I have the time to mess with it. At the moment I'm a bit under the gun and it's taken way too long to get to this point.
As it stands I built this using the star shape since I already had each star sized and positioned before coming on the forum.
So here's how I did it from a novice perspective.
I cut and pasted the each previous motion path to the next star then positioned it using the control points.
I figured now I can apply the 3D to each star individually to get the same effect as Paramont as indicated with the first star that comes into frame. It won't be a simple cut and paste of the keyframes like I can with the scale but it will get there.
I figured the way the stars align (no pun) I had to treat them independently.
It didn't take as long as I thought but no doubt an unorthodox way of doing it.
Am I on the right track here?
Thanks for helping me get this far.
Michael
Mark Spencer
Re: Trailing stars
on Aug 28, 2014 at 9:46:38 pm
Not bad! I do think you'd find it easier with text on a path.
Mark Spencer
Michael Campione
Re: Trailing stars
on Aug 29, 2014 at 8:47:37 pm
I will most certainly give it a try when I have more time to play. :-)
Thanks again.
Mark Spencer
Re: Trailing stars
on Aug 29, 2014 at 9:31:49 pm
So I posted a video example but not sure how to get it right here.
Mark Spencer
Michael Campione
Re: Trailing stars
on Aug 29, 2014 at 9:47:58 pm
I just uploaded to youtube then post the link. If I'm understanding you.
