Color balance filter
COW Forums : Apple Motion
Bruce Breidbart
on Aug 26, 2014 at 7:25:36 pm
I need to do a quick color correction in Motion 5, on one shot that was not white balanced correctly.
The color balance filter filter sound like the right choice to make the fix.
I'm new to this filter and not sure what the color picker does to help correct poorly balanced shots ?
I don't see an auto correct on this filter.
Is it a slow process of pulling back on the opposite colors ?
thanks in advance
BB
Mark Spencer
Re: Color balance filter
on Aug 26, 2014 at 7:28:51 pm
Yes. Frankly I would do this in FCP X, the auto balance feature will do it in a split-second.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Bruce Breidbart
on Aug 26, 2014 at 9:39:58 pm
Mark, thanks for the quick reply.
BUT, when I did a search, it was YOU that
suggested using this filter. I know you are a very busy guy but,
I'm in Motion 5 trying to use a new filter. Thanks for your help.
BB
Mark Spencer
on Aug 26, 2014 at 9:44:49 pm
I suggested it for color correction, I don't recall suggesting it for white balancing although it is your best option inside of Motion. You'll need to turn on the RGB values to show at the top of the Canvas to determine if you are balanced or not.
Mark Spencer
