Importing into Motion...and rendering therein
COW Forums : Apple Motion
John Mendelsohn
on Aug 18, 2014 at 3:46:01 am
Is there a way, when importing multiple JPEGs or PNGs, to avoid each of them going into a separate group?
Also, why, when I've adjusted the In and Out bars on the Timeeline, does the program render even the stuff I wish to exclude? How to get it to render only between In and Out, please?
Thanks very much in advance.
Simon Ubsdell
Re: Importing into Motion...and rendering therein
on Aug 18, 2014 at 12:49:27 pm
[John Mendelsohn] "Is there a way, when importing multiple JPEGs or PNGs, to avoid each of them going into a separate group?
Shift select them in the Finder or File Browser and drag them into a group - rather than hitting the Import button.
Also, why, when I've adjusted the In and Out bars on the Timeeline, does the program render even the stuff I wish to exclude? How to get it to render only between In and Out, please?"
If you have a play range created (Alt/Cmd+I to set the inpoint, Alt/Cmd+O to set the outpoint), the Export movie dialogue will allow you to choose Use Play Range for the export duration. If you don't have a play range set, this option will be greyed out.
Simon Ubsdell
tokyo-uk.com
John Mendelsohn
on Aug 18, 2014 at 4:46:34 pm
Thanks, Simon.
