Thought bubble with video clip inside?
COW Forums : Apple Motion
Michael Kwan
on Jul 16, 2014 at 4:13:25 am
I'm familiar with FCPX, but I'm a beginner in Motion. How do you make a thought bubble with a video clip inside of it? Here's an example of the result I'd like to get:
http://www.revostock.com/After-Effects-Project/311928/Media-Thought-Bubbles...
Thanks.
Andy Neil
Re: Thought bubble with video clip inside?
on Jul 16, 2014 at 5:01:28 am
You do this by duplicating your thought bubble layer (which you make with the bezier shape tool). You put an outline on the top layer and then add an image mask to it and drag the bottom layer onto the image mask. Set the mask to subtract and it will cut out the bubble.
You can scale the top layer up a bit if you want to alter how much of an edge you have surrounding your bubble. You can feather the bottom shape to change how well it composites with the top shape.
Hope this helps.
Andy
https://plus.google.com/u/0/107277729326633563425/videos
Mike Ron
on Jul 17, 2014 at 4:43:21 am
Thanks. I'll give that a try!
