Color and/or Gamma shift between photoshop and motion
COW Forums : Apple Motion
ellen osborne
on May 21, 2014 at 4:43:05 pm
HI
My psd documents are very washed out when I import them into Motion. If I import the same doc into AE, the colors remain accurate. There must be a setting somewhere in Motion to make it read the color correctly from photoshop, but I can't seem to find it.
Color setting in photoshop is Colormatch RGB 8 bit. Using Motion 5. Photoshop CS6. Mac Pro. Mavericks.
Thanks for the help.
Robin S. Kurz
Re: Color and/or Gamma shift between photoshop and motion
on May 21, 2014 at 6:01:38 pm
I would suspect that it has layer effects, adjustment layers or the likes. Motion doesn't do layer effects etc.
ellen osborne
on May 21, 2014 at 6:07:05 pm
There are no layer effects or adjustment layers.
Gareth Randall
on May 27, 2014 at 6:00:08 am
I can confirm that I've seen a gamma shift in the past after exporting stills from FCP7, working on them in PS (usually painting things out) and then reimporting them. But I've just tried a few experiments now, and I can't replicate it!
