Arri Footage workflow (ColorSpace REC709)
COW Forums : Apple Motion
Thomas Frank
on Mar 30, 2014 at 4:28:10 am
Is there a Arri footage workflow in Apple Motion?
I noticed when I export and Arri footage from motion the colorspace is waked.
Robin S. Kurz
Re: Arri Footage workflow (ColorSpace REC709)
on Mar 30, 2014 at 6:22:54 pm
Not sure what "waked" means in this context, but you might want to look into the LUT Utility from Color Grading Central.
http://www.colorgradingcentral.com/lututility
Thomas Frank
on Mar 30, 2014 at 7:00:06 pm
Have that and it works fine, but the problem is when I export the composition. The ProRes files has no colorspace information meaning adding the Arri Lut in FCP X does not work. :(
Thomas Frank
on Apr 9, 2014 at 7:53:29 am
I will take it... it is not possible to export ProRes with Arri colorspace information from Motion.
