 | Adjust Z position and scale at the same time
on Mar 27, 2014 at 11:56:35 pm |
I seem to remember a short cut or modifier key to scale an object while adjusting it's z position.
I am importing a .psd so everything is flat. I want to ad some z space for a camera move, but I need the final look to be the same as the flat .psd. When increasing the z position the object gets larger so I need to scale it down. I would like to adjust the z position and have the size stay relative to the rest of the frame.
I can easily adjust the z position and then scale it up or down, but I do this a lot and it would really help to do it in one step.
Glenn
 | Re: Adjust Z position and scale at the same time on Mar 30, 2014 at 6:26:26 pm |
Hold the COMMAND key while adjusting the Z-position in the HUD.
 | Re: Adjust Z position and scale at the same time on Mar 31, 2014 at 2:16:11 pm |
Thank you Robin. I tried every key combination in the inspector window and on screen controls, but I did try the HUD.
