Graphic linked with FCP editable text
COW Forums : Apple Motion
Dylan Harrelson
on Mar 15, 2014 at 9:13:51 am
My station is transitioning to Final Cut Pro X and I am in the process of creating FCP generators to work in conjunction with our in-house graphics package. I am trying to put together a simple text reference generator for when we use video from other sources.
I've set up a rig to toggle if the source is YouTube content or not but the courtesy text would be modified in Final Cut Pro. I would like to see if the YouTube graphic can be offset to reflect the text input in Final Cut Pro using the Link behavior.
Does anyone have any advice on how to properly set it up.
Dylan Harrelson
Digital Media Professional
Mark Spencer
Re: Graphic linked with FCP editable text
on Mar 15, 2014 at 2:39:54 pm
You are going to need to publish the position of the logo and move in FCP X depending on the text length. There is no exposed parameter in Motion that describes text length.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Dylan Harrelson
on Mar 20, 2014 at 2:40:07 am
Thank you Mark! I ended up designing just that I believe. I published the X position to allow for the offset of the logo depending on the text input. Thanks for the advice!
Dylan Harrelson
