Extra keyframes in Motion 5
COW Forums : Apple Motion
Marv Camalich
on Jan 3, 2014 at 4:21:58 pm
Hi everybody!
I just moved from Motion 4 to Motion 5, and Im having a hard time with the keyframes. Motion 5 is creating new keyframes even if the record button is off. This is a problem when I want to modify the original position or size of an object, Motion 5 considers this change as a new movement and creates a new key-frame. The past version of Motion didn't do this.
Can somebody help me out?
-Marvin-
Möller Publicity Agency
Producer
Marv Camalich
Re: Extra keyframes in Motion 5
on Jan 3, 2014 at 4:35:56 pm
I tried double clicking the record button and a menu appeared none of those options worked.
Producer
Robin S. Kurz
on Jan 3, 2014 at 5:38:58 pm
Yes, I know what you mean. I'm not terribly excited about the change either, but it was (unfortunately for us Motion old-timers ;) done to work like FCP X (I'm guessing) so as not to confuse newcomers i.e. people coming to Motion from FCP X for the first time. Which also explains the disappearance of the "Record only for animated parameters" option in the record options window. ;)
To move an object and maintain the keyframes' relative position without creating (a) new one(s), you need to hold the ⌥ and ⌘ keys.
Marv Camalich
on Jan 7, 2014 at 5:14:03 pm
Thank you for commenting, but that didn't work.
I really don't understand why they mess with the principles of animation, this software has disappointed me so far. Thanks again thou.
Producer
Heintje Fernandez
on Aug 8, 2015 at 4:09:34 am
It did work for me...you have to steady click on the image that you need to change, press command and option then try moving it...hope it works for you now.
