Floor-less Reflection
COW Forums : Apple Motion
Don Smith
on Dec 17, 2013 at 12:20:59 pm
There is a technique of creating of creating what I call 'floor-less' reflection that involved cloning a layer, flipping it and putting a rectangle over the clone and changing its fill to gradient and putting it into an image mask applied to the clone. Yada yada yada.
It seems that somewhere I heard that its much simpler to get a reflection without putting in a reflective floor using Motion 5.
Is that true or is it wishful thinking?
David Eaks
Re: Floor-less Reflection
on Dec 17, 2013 at 12:49:56 pm
I think I remember seeing something about that too, maybe Macbreak Studio? I'll try to remember...
David Eaks
on Dec 17, 2013 at 1:18:37 pm
Duplicate the image, flip it upside down, move it to the bottom of the original and blend with a feathered mask and opacity?
Robin S. Kurz
on Dec 17, 2013 at 1:34:01 pm
[Don Smith] "There is a technique of creating of creating what I call 'floor-less' reflection that involved cloning a layer, flipping it and putting a rectangle over the clone and changing its fill to gradient and putting it into an image mask applied to the clone. Yada yada yada."
That's the only way that I would know of without the use of an actual reflective object. Otherwise you could try using a white "floor" for the reflection and then applying it with a composite mode such as Overlay over your backplate, if that's what it is you're looking to do.
- RK
Andy Neil
on Dec 18, 2013 at 3:32:23 am
So, you're looking for a way to create a reflection that doesn't use either of those techniques?
Andy
http://www.timesavertutorials.com
David Eaks
on Dec 18, 2013 at 9:05:33 am
Or a drop shadow like in the Dramatic title in FCPX?
Don Smith
on Dec 18, 2013 at 10:27:53 am
Andy… Yes. I sometimes need the reflection as if a floor is there but without a floor object to block the background. There's the old technique as I describe in my OP but I thought I had heard somewhere along the way that you could achieve that reflection in the newest Motion without using a floor object and without the complexity hoops of the original technique.
It must have been a hallucination! :)
NewsVideo.com
Mark Suszko
on Jan 14, 2014 at 5:38:10 pm
I'm still stuck in Motion 4 but seem to remember it has a "reflection" filter somewhere, might be M5 does too. I've manually made reflectives like this, in the way you've described, but the free plug-in from Noise Industries, called cover flow or cover flux, seems like an easy to customize starting point. Maybe you can modify that into a template that is re-useable for you?
Stephen Smith
on Jan 14, 2014 at 5:41:57 pm
Reflections are easy to do in Motion 4 with its built in reflection feature. Take a look at this tutorial: http://library.creativecow.net/articles/smith_stephen/reflection_4.php
Stephen Smith
Utah Video Productions
Check out my Vimeo page
