Text facing Camera?
COW Forums : Apple Motion
Thomas Frank
Text facing Camera?
on Dec 5, 2013 at 10:09:43 am
is there a way to have the Text face the camera at all times in a 3D scene?
The camera is rotating around a map and I like to have the city names facing the camera.
Thank you
Simon Ubsdell
Re: Text facing Camera?
on Dec 5, 2013 at 12:23:02 pm
Easiest way is to make the text layers 2D rather than 3D. Would that work for your project?
Simon Ubsdell
http://www.tokyo-uk.com
Thomas Frank
on Dec 5, 2013 at 1:24:44 pm
Well the text are on top of a location (City) and should stay at that position just facing the camera. Like something from Google Earth
Simon Ubsdell
on Dec 5, 2013 at 1:34:26 pm
Try linking the XYZ rotation of the Text layer (or text group) to the rotation of the camera. That should do it.
Simon Ubsdell
Mark Spencer
on Dec 5, 2013 at 1:44:48 pm
You can use the Point At behavior to have the text always face the camera. Set the transition to zero.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Simon Ubsdell
on Dec 5, 2013 at 2:04:46 pm
I thought that Point At only gave you the option of one axis? I guess you'd need to have three instances if you wanted it completed locked.
Link rotation is marginally easier in this case possibly?
Simon Ubsdell
Mark Spencer
on Dec 5, 2013 at 2:19:02 pm
Yes you need to choose an axis but if you choose the default, z, and set the Transition value to 0, the text will always point at the camera - it's z-axis will point at the camera.
Mark Spencer
Simon Ubsdell
on Dec 5, 2013 at 2:26:20 pm
[Mark Spencer] "Yes you need to choose an axis but if you choose the default, z, and set the Transition value to 0, the text will always point at the camera - it's z-axis will point at the camera."
Thanks, Mark. Another thing I didn't know ;-)
Simon Ubsdell
Thomas Frank
on Dec 5, 2013 at 1:59:56 pm
Nope it didn't work. :(
Mark Spencer
on Dec 5, 2013 at 2:00:49 pm
It certainly works for me. Did you add the camera to the source well? Change the transition time?
Mark Spencer
Thomas Frank
on Dec 5, 2013 at 2:20:09 pm
I add the camera to the well but the text spun in another direction and its not moving with the camera
Mark Spencer
on Dec 5, 2013 at 2:21:46 pm
I can't tell what's wrong without seeing your project but if you set the Transition value to 0 and the Source to the Camera with the Z-axis selected, the text will face the camera. Is the text in a 3D group? Tough to trouble shoot but absolutely should work.
Mark Spencer
Thomas Frank
on Dec 5, 2013 at 2:44:47 pm
This is what I have and what I get:
Mark Spencer
on Dec 5, 2013 at 2:49:57 pm
That's not the Point At behavior. That's the Link parameter behavior. I'm suggesting you use the Point At behavior (in the Basic Motion category) instead of the Link behavior.
Mark Spencer
Thomas Frank
on Dec 5, 2013 at 3:27:16 pm
Ops got it! Thank you !
