Problem with Particle Trail and Short Motion Path
COW Forums : Apple Motion
Nikolas Bäurle
on Nov 21, 2013 at 12:19:32 pm
I built a short logo animation last night, just for practice.
I made a particle emitter from a circle with a scale over life behaviour , and attached it to a motion path, that circles around in the middle. The project is 400 frames long, and I left all the elements in that length during the building process.
The moment I shorten the motion path to under 100 frames the motion path starts turning into an octagon, even if I increase birthrate...
My solution to this was simply to make the animation longer and speed it up in Final Cut.
Is there another solution to this? What am I doing wrong?
"Always look on the bright side of life" - Monty Python
