Motion 5 match match move video layer gone when switching from "transformation" to "Four corners"
COW Forums : Apple Motion
Zeno Groenewegen
on Oct 9, 2013 at 9:35:13 pm
I motion tracked a Tv in a scene at the four corner points of the Tv and motion analysed it. The i added the footage to be in the Tv, set match move and dragged the analysed motion in the Match move. That worked until the Tv pans out of the scene so i switch from type "transformation" to "Four corners" but........now the footage in the Tv is invisible, when switching back to "transformation" its there. Whats happening here?
Zeno Groenewegen I Dutch producer & musicvideo director
Simon Ubsdell
Re: Motion 5 match match move video layer gone when switching from "transformation" to "Four corners"
on Oct 10, 2013 at 4:49:01 pm
Make sure your corners are matched up correctly to the trackers - depending on what order you set the trackers in, the match-mived image might disappear.
Simon Ubsdell
http://www.tokyo-uk.com
