Weird behaviour of text transitions
COW Forums : Apple Motion
Sascha Engel
on Aug 15, 2013 at 10:03:14 am
Hallo Everybody,
I have following issue: I have a text, certain Text style with Glow applied to it. Then I drop a Text behaviour, for example a Glow In one. Unfortunately, there is a weird jump in the way the text appears, right after the Transition is finished. I thought, maybe it's only in the Canvas and Export it, but it's the same. The moment the Transition is finished , the Glow suddenly jumps on. So I thought maybe it's connected to the fact , that I have Glow on the text set to On, but even without there is a weird jump on the end of the transition.
What can this cause and how to avoid it?
I have been absent from Motion for a whil, but I never remembered such a problem.
Thanx.
Greetings,
Sascha Engel
TIME BANDITZ Productions
http://www.youtube.com/taikang
Sandeep Sajeev
Re: Weird behaviour of text transitions
on Aug 15, 2013 at 5:43:45 pm
Are your Text Behaviours and Effects starting at the same point in time? You can expand the Timeline view to check this.
Sandeep.
Sascha Engel
on Aug 15, 2013 at 6:28:21 pm
Yes, Text layer and text behaviour are starting both at frame 0 and all settings in the text as well.
Sascha Engel
