Scribble Effect?
COW Forums : Apple Motion
Chris Northcross
Scribble Effect?
on Jun 15, 2013 at 3:26:42 pm
I know that I can achieve a "scribble" type effect using After Effects. I'm curious if anyone knows of a way to do it in Motion 5? Thanks in advance for your help!
"Whether you think you can or can't, you're right."
Andy Neil
Re: Scribble Effect?
on Jun 15, 2013 at 4:41:05 pm
Can you provide an example of what you're asking about? I can think of a couple different ways to produce something that I'd call a "scribble" effect.
Andy
http://www.timesavertutorials.com
Chris Northcross
on Jun 15, 2013 at 5:39:46 pm
Sure
The picture on the the description page more or less shows what type of effect I'm looking for.
http://library.creativecow.net/devis_andrew/AE-Scribble-and-Stroke-Effect/1
Simon Ubsdell
on Jun 15, 2013 at 5:47:33 pm
There's no equivalent to the Ae Scribble Effect but this would be pretty easy to achieve by hand using the Paint tool - more time-consuming and less automated but it would still work.
Simon Ubsdell
http://www.tokyo-uk.com
Chris Northcross
on Jun 15, 2013 at 6:12:13 pm
How would you handle the fill texture Simon?
Simon Ubsdell
on Jun 15, 2013 at 6:14:13 pm
Actually there's a pretty easy way to do this and get a good result.
Paint a single rough line as the base of your "scribble" - a nice rough angled stroke works well. Set the width to what you want.
Add a replicator to the "scribble" line. Set the Shape to Image and the Arrangement to Tile Fill.
Add the shape you are trying to fill to the Image well - I used text but you can use anything that has an alpha channel to define the overall shape.
Set the number of Columns and Rows to be sufficient to fill your shape the way you want it.
Increase the Scale Randomness to get a more varied look.
To get an animated scribble you can for example apply a Randomise Behavior to the X Scale and adjust the Speed and Noisiness to taste.
You may want to add a second version of this replicator using a different source "scribble" to get a bit more randomness but that should give you the basics to experiment with.
Here's my very quick test:
Simon Ubsdell
Chris Northcross
on Jun 15, 2013 at 6:17:08 pm
Outstanding! Still learning all the joys of the replicator. I was trying to paint individual strokes and use a wiggle shape behavior, but wasn't getting the results I was looking for. This looks much better. Many thanks!
Mark Spencer
on Jun 15, 2013 at 6:27:27 pm
You can and the Wriggle Shape behavior to a shape to make it move like the scribble effect.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Simon Ubsdell
on Jun 15, 2013 at 6:36:43 pm
[Mark Spencer] "You can and the Wriggle Shape behavior to a shape to make it move like the scribble effect."
Of course! How could I forget that? Amazingly useful behavior as are the other shape behaviors Oscillate and Randomise. Much better than what I suggested.
Simon Ubsdell
Mark Spencer
on Jun 15, 2013 at 6:59:41 pm
Very rare is it that I have something to offer beyond what you usually suggest Simon :-)
Be aware, Chris, that this behavior is pretty demanding on your system, especially if you have a lot of points.
Mark Spencer
Andy Neil
on Jun 15, 2013 at 7:07:44 pm
[Mark Spencer] "Be aware, Chris, that this behavior is pretty demanding on your system, especially if you have a lot of points."
Or if you're replicating a paint stroke which is already hard on the system.
Andy
Simon Ubsdell
on Jun 15, 2013 at 7:24:16 pm
[Mark Spencer] "Very rare is it that I have something to offer beyond what you usually suggest Simon :-)
Thanks, Mark - certainly not true at all but very nice of you to say so ;-)
Incidentally, I am getting very smooth real-time playback with your wriggle shape suggestion - maybe my line doesn't have that many points but it does seem to work very nicely as an overall effect.
Anyway, this is a good effect that I've just added to my library so thanks for the inspiration.
EDIT: Just to correct my previous recommendation to Chris, if you want more complexity you don't have to make a second replicator just add a new line or lines to the first replicator which is a much more efficient way of doing it.
Simon Ubsdell
Simon Ubsdell
on Jun 15, 2013 at 5:17:27 pm
Click on the Paint Brush tool and scribble away? Motion's paint capabilities are stunningly good.
Simon Ubsdell
Chris Lehmann
on Jun 17, 2013 at 4:48:29 pm
I've been using the Motion paint function extensively for the past few weeks and it can be incredibly powerful. Just one thing to look out for is if you are using A LOT of paint objects in one project, the file size will balloon to several hundred megs. I looked at the XML in the .motn file and it's storing X/Y coordinates for thousands of vertices up to the 10th decimal point! For me this caused major slowdowns when working, and 2-4 second freezes during auto-saves.
I solved this by splitting the animation into smaller separate projects, but if anyone has any suggestions on how to speed this up I'd be very thankful.
Simon Ubsdell
on Jun 17, 2013 at 5:05:22 pm
[Chris Lehmann] "I've been using the Motion paint function extensively for the past few weeks and it can be incredibly powerful. Just one thing to look out for is if you are using A LOT of paint objects in one project, the file size will balloon to several hundred megs. I looked at the XML in the .motn file and it's storing X/Y coordinates for thousands of vertices up to the 10th decimal point! For me this caused major slowdowns when working, and 2-4 second freezes during auto-saves. "
Make sure you check the smoothing checkbox in the Painstroke HUD before you start making loads of complex shapes. Without this turned on you will get an insane number of points, whereas if you enable smoothing you will get a bezier shape with massively fewer points.
You can see the difference from this example:
Simon Ubsdell
Chris Lehmann
on Jun 17, 2013 at 5:22:23 pm
I just did a quick test for masking characters and drawing them on screen. Turning on smoothing before drawing the mask with a tablet reduced the number of points from 2858 to 246! I don't see any way of retroactively applying this (like a reduce points feature) but this will help a lot going forward. Thanks Simon!
Andy Neil
on Jun 17, 2013 at 5:06:48 pm
Aside from breaking up the project, your best option is to manually clean up the excess control points. Even a simple paint stroke drawn from a tablet can have dozens of unneeded control points. Sadly, there's no "reduce points" feature (which would be nice), but you can delete excess points and adjust your remaining point's bezier handles to get the same look with half the number of control points. I also sometimes switch to b-spline points (depending on the look of the stroke) to get the number of points down as much as I can.
A good feature request would be button to have Motion clean up points automatically, leaving you with just some tweaking adjustments. Sort of like the reduce keyframes feature.
Andy
Simon Ubsdell
on Jun 17, 2013 at 5:10:15 pm
[Andy Neil] "A good feature request would be button to have Motion clean up points automatically, leaving you with just some tweaking adjustments. Sort of like the reduce keyframes feature."
Agreed.
Simon Ubsdell
Simon Ubsdell
on Jul 14, 2013 at 8:38:13 pm
[Chris Northcross] "I know that I can achieve a "scribble" type effect using After Effects. I'm curious if anyone knows of a way to do it in Motion 5? Thanks in advance for your help!"
Here's a tutorial that shows how you can achieve this effect in Motion:
Hope that's of interest.
Simon Ubsdell
