Motion 4 question
COW Forums : Apple Motion
Michael West
Motion 4 question
on May 22, 2013 at 1:41:59 pm
I'm using the "underwater" behavior on an object, but as it moves, the front edge and the back edge "disappear" under the border of the object.
How can I make it move but not be cut off?
Thanks.
Michael
Chris Lehmann
Re: Motion 4 question
on May 22, 2013 at 2:23:24 pm
Try moving the object into a group and applying the behavior to the group instead. Also, make sure under group controls that "fixed resolution" is not checked.
Michael West
on May 22, 2013 at 3:49:07 pm
Chris (and Stephen):
Thanks for the rapid response.
Odd, though, Chris, because the "fixed resolution" was already unchecked, but when I checked it, it expanded the borders and the problem was solved.
Regardless, all is well and thanks again.
Michael
Stephen Smith
on May 22, 2013 at 2:55:43 pm
I tried to re-create your problem with the Underwater filter and I can't get the edge to disappear. What are your settings. Have you tried it with another clip to see if it is the clip? Can you zoom in on the clip to cover up the missing edge?
Stephen Smith - Follow me on Behance
Utah Video Productions
Check out my Vimeo page
