Is it possible to publish the stabalizer effect back into FCPX
COW Forums : Apple Motion
Chris Lambert
on May 8, 2013 at 1:46:48 pm
This may seem like an odd request but I am currently able to stabalize footage in a multicam clip of an event that I am editing in which one of the cameras was a bit wobbly.
When I click on the clip in FCPX inspector there is currently no option for stabalizer a quick google search shows that this is not a isolated find.
Rather than have to go into the angle editor and apply the effect to the entire clip which I would imagine would take up a lot of analysis time as well unnesecary HDD space is it possible to publish a Motion effect using only the stabalizer effect back into FCPX so that I can grab this from the effects pannel and drop it onto the timeline of the cut that requires it?
I am overly familiar with publishing effects and have only basic work in this in the past but I cannot get this to work at the moment is this possible?
Mark Spencer
Re: Is it possible to publish the stabalizer effect back into FCPX
on May 8, 2013 at 6:02:51 pm
No, you can't publish a Motion effect that stabilizes. Why not locate that clip in the event, set a range for the shaky part, and stabilize it there? It should pass through to your multicam edit automatically.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
