Motion 5 : Set Anchor Point default?
COW Forums : Apple Motion
Heather L. Truelove
on Apr 26, 2013 at 4:52:51 pm
Good morning,
Is it possible to set the anchor point to default always to dead center on any object?
I'm finding that, when I apply a behavior, the anchor point is distant from the object I've applied it to.
Thank you,
h.
(Beginner)
Mark Spencer
Re: Motion 5 : Set Anchor Point default?
on Apr 26, 2013 at 5:04:36 pm
Except for text objects, the anchor point of a layer is already at the center by default.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Heather L. Truelove
on Apr 27, 2013 at 12:47:37 pm
Thanks Mark. I am working predominantly with text objects--is there a way to set a default for those? The only option I have figured out is in the inspector manually dragging the values until the anchor point seems to line up visually. I tried selecting the anchor point tool and dragging but that doesn't seem to work either.
Mark Spencer
on Apr 27, 2013 at 2:43:46 pm
Why can't you use the Anchor Point tool in the Canvas? Works for me - it even shows you exactly where to drag:
No way to set the default.
Mark Spencer
Heather L. Truelove
on Apr 27, 2013 at 5:15:20 pm
Yeah, see, I'm not getting what you show. For me, the positioning arrows are some distance from the text box. Hence my query. (Motion is on my work computer, else I'd share a sceen capture of what I'm seeing. I can do so on Monday.)
