Workflow for keying Master Clip before edit with FCP
COW Forums : Apple Motion
Adam Cardwell
on Apr 17, 2013 at 5:11:51 pm
Hey guys,
I am looking for an easy process of alpha keying a full master clip I captured from FCP 7 using Motion, then sending the keyed footage back to FCP as a master clip. Here is my desired workflow:
FCP (Log and Capture) -> Motion (key out green) -> FCP (pre-keyed for edit)
Normally in FCP I would lay down the entire sequence, including B-Roll, inserting only the needed sections of my un-keyed footage. This usually results in having the un-keyed footage sectioned out in different areas of my sequence. Once I have the final product, I would then have to send each of the un-keyed clips separately to Motion for keying. This is a pain, and there must be an easier way to do this. Right now, here is my workflow:
Un-keyed Clip 1 -> Motion -> FCP.
Un-keyed Clip 2 -> Motion -> FCP.
Un-keyed Clip 3 -> Motion -> FCP.
....etc.
Anyone know a way to solve this problem without straying from the FCP -> Motion streamline? (No exporting to file)
Adam
Stephen Smith
Re: Workflow for keying Master Clip before edit with FCP
on Apr 17, 2013 at 9:33:59 pm
I'm not sure why you want to just key a clip in Motion 4. The Primatee RT keyer is in FCP as well. Or you can use the Chroma Keyer.
If you don't want to export out a clip you can treat the Motion project file like it is a clip and render it in FCP, keep in mind that the Render time will be long.
Stephen Smith - Follow me on Behance
Utah Video Productions
Check out my Vimeo page
