Publishing a title copy
COW Forums : Apple Motion
Tom Fox
on Mar 22, 2013 at 5:05:52 pm
Hello all,
I trying to edit a copy of FCPX's "Dramatic" Title generator in Motion.
I have set the scale slider to "publish" so that I can adjust the timing. The problem is that though the animation seems to work fine in Motion, when placed on the timeline in fcpx , the text is static.
Is there something simple that I am doing wrong?
Cheers,
T
Alex Gollner
Re: Publishing a title copy
on Mar 23, 2013 at 12:24:55 am
If the scale slider is published, you can now set scale keyframes in Final Cut Pro to change the value for scale over time.
A way of using a different sets of keyframes that have been set in Motion is to assign each set to a rigged widget.
@Alex4D
___________________________________________________
Alexandre Gollner,
Editor, Zone 2-North West, London
alex4d on twitter, facebook, .wordpress.com & .com
Tom Fox
on Mar 23, 2013 at 10:09:42 am
Hi Alex,
A closer study showed that the z-index, as opposed to scale, was used in the above effect. No matter, I made z index publishable, but there is still no movement in fcpx.
Is it therefore the case that if a parameter is published then it is essentially re-set in fcpx? And that one has to create a widget to override that?
I am away from my kit this weekend so cannot look.
Love your blog/work btw.
T
