Vertical Text Alignment
COW Forums : Apple Motion
Stephen Botting
on Feb 11, 2013 at 3:59:11 am
Hi All,
I'm creating a text field that will be edited in FCP, but the length of text in this field will change. Is there a way to make it when a new line is added to the text, all the lines moves up to make room for the new one, thus the bottom line of text is always the same vertical position.
Stephen
Mark Spencer
Re: Vertical Text Alignment
on Feb 11, 2013 at 4:02:16 am
Set the Layout Method (Text > Layout) to paragraph and set the Vertical Alignment (Text > Format) to bottom.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Stephen Botting
on Feb 11, 2013 at 8:24:26 pm
Thanks for the reply.
I cannot find the Vertical Alignment option in Format. I'm only using Motion 4, this isn't a new feature of Motion 5 is it.
Stephen
http://www.43south.co.nz
Mark Spencer
on Feb 11, 2013 at 9:37:23 pm
Could be. I'm on 5 now.
Mark Spencer
