Simulating planets around sun - having 2.5D trouble.
COW Forums : Apple Motion
Tangier Clarke
on Feb 7, 2013 at 10:27:19 pm
The planets are basically circles. The Sun is also a circle with the sphere filter on it because I used a rectangular image of the sun; animating the revolutions using the sphere filter position properties.
I have the planets (circles) on a circular motion path, rotated 90 degrees so the circular path is on a horizontal plane.
I just can't figure out how to get the planets to "disappear behind the sun. My circular motion path is larger than the sun sphere.
I'ved toyed around with the z parameter of the different object groups with no luck yet.
Any advice?
Tangier
Tangier Clarke
Re: Simulating planets around sun - having 2.5D trouble.
on Feb 7, 2013 at 10:54:09 pm
Lol - figured it out. Never the less if anyone has insight into this, it'd still help.
I suppose I should have just used Blender to "really" do it right.
T
Tangier
Mark Suszko
on Feb 15, 2013 at 10:01:55 pm
What was your solution, BTW?
