Keyer tool doesn't work! Deadline tomorrow!
COW Forums : Apple Motion
AJ Robinson
on Jan 26, 2013 at 2:38:50 am
Hey guys!
Well, this is how my problem goes.
Since the update (5.06), when I apply Keyer, and hit sample color or edges, the select color tool or edges does not come up. Instead it selects the transform tool. So I can't select the color I want! When I try to, it just drags the video!
I need to get this video up by tomorrow, but If I can't key it, I can't. So, please help me quickly!
~AJ
Mark Spencer
Re: Keyer tool doesn't work! Deadline tomorrow!
on Jan 26, 2013 at 5:15:50 am
Trash your preferences, that should fix it. If not, delete the app and redownload from the app store.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
AJ Robinson
on Jan 26, 2013 at 6:39:08 pm
Seriously? I trashed all the prefs like a hundred times. Well, I still got a few hours, I'll just re-download it.
Thanks Mark,
~AJ
Chris Northcross
on Jan 27, 2013 at 5:21:20 am
You could also try keying in Final Cut Pro and then exporting the clips you need out and then import 'em into Motion too. Downloading it again might be your best bet in the long run but if you're up against the clock, that might save you a little time in the event that the re-download doesn't work.
"Whether you think you can or can't, you're right."
