Animating audio waveforms to shapes?
COW Forums : Apple Motion
Offbeat Bryce
on Jan 18, 2013 at 3:43:23 am
Hello
I have Apple Motion version 5.0.6. With my older version of Motion that came with Final Cut Pro 7 I could select a behavior that would create keyframes from audio wave forms that I could then sync up to shapes like for example a mouth and it would animate to the audio waveform. However the only keyframes for audio I find in version 5.0.6 is fade and pan. Do you know how I achieve this same animation for mouth in my current version?
Bryce
Jeff Greenberg
Re: Animating audio waveforms to shapes?
on Jan 18, 2013 at 12:23:45 pm
It's a parameter behavior called Audio.
Best,
Jeff I. Greenberg
Author/Master Instructor/Speaker/Consulting
My contact info and more
Bryce Douglass
on Jan 18, 2013 at 5:59:33 pm
[Jeff Greenberg] "It's a parameter behavior called Audio."
That's what I'm under. There is only pan and fade mode.
Jeff Greenberg
on Jan 18, 2013 at 6:17:24 pm
It's not in the audio behaviors. It's in the parameter behaviors.
Alternatively, you can right click on a parameter (such as scale) and attach a behavior to that parameter.
bug me if you can't find it.
Bryce Douglass
on Jan 18, 2013 at 8:10:50 pm
I found it. when I create a separate layer for the mouth to move via the audio behavior the layer moves up instead of down. i have to selected for position Y. How do I get it to move down up apposed to up and down?
Jeff Greenberg
on Jan 18, 2013 at 8:54:46 pm
Change the scale (you'll have to click in the field) to -1. That inverts the data. You can adjust the scale higher/lower for a greater/lesser effect
Best,
Jeff I. Greenberg
Bryce Douglass
on Jan 18, 2013 at 10:15:12 pm
Another problem is this. When I mask out the mouth I put a black layer behind it. Theoretically animating the mouth mask should cause black to appear underneath the mouth layer right? Cause it's not.
Don Smith
on Jan 21, 2013 at 10:58:21 am
It sounds like you're animating the mask and not animating the mouth, which should be cut out from the face and be a separate layer. Animating the mask would only make it move over the face.
Forget the mask.
Cut the mouth from the face into a separate layer. On the face, have black where the missing mouth is.
Animate the mouth (lower lip to chin, actually).
Don Smith
NewsVideo.com
