Markers
COW Forums : Apple Motion
Praveen Nu
Markers
on Jan 9, 2013 at 12:25:26 pm
Hi all,
I have created on animation in Motion which has an "in" motion, then loop, then "out".Added the markers also. But loop and build out marker is not working at the same time if build in is there.Any solution?..It should play build in then loop(n times) then build out..
Pls help me.
Thank you,
Praveen N U
http://www.nupraveen.com
Mark Spencer
Re: Markers
on Jan 9, 2013 at 1:37:10 pm
It doesn't work that way. You have to choose. Either Build In/Out (one or both) or Loop. Can't have a loop marker together with Build In or Out.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
