Image with Alpha Channel not showing up in Motion 4
COW Forums : Apple Motion
Michael Barnes
on Dec 30, 2012 at 2:16:51 pm
Hello,
I found a sun glow image in a stock library that I would like to use as a transition between shots in FCP 7.
I imported the image into Motion 4. The image reportedly has an alpha channel. The problem is that the sun glow is not showing up in Motion.
I tried playing around with View>channel alpha settings in Motion and this did not work. Any suggestions on being able to view the image in Motion, then export with alpha to play in FCP?
Thanks.
