Wireframe
COW Forums : Apple Motion
AJ Robinson
Wireframe
on Dec 4, 2012 at 12:08:05 am
Hey guys,
I am doing a review of my quad copter for a contest. I would like to turn the quad or parts of it into wireframe. What would be the easiest way to go about doing that?
Thanks guys,
~AJ
Jason Watson
Re: Wireframe
on Dec 4, 2012 at 2:59:58 am
It sort of depends on how you want the transformation to occur, how complex the wireframe is, etc. Something like Cinema 4D would probably be the easiest way to create the wireframe itself, but you could also manually draw out the wireframe in Motion- it would be quite tedious, but possible.
AJ Robinson
Re: Wireframe
on Dec 4, 2012 at 3:21:09 pm
Couldn't I just make my image an image mask over the grid generator?
~AJ
Jason Watson
Re: Wireframe
on Dec 4, 2012 at 3:34:26 pm
That would be one option, but depending on the complexity of your image it's going to look really tacked on since the segments aren't going to follow the shape like a wireframe actually would, especially on the edges. (which will abruptly cut off) It would sort of being like drawing a silhouette on a piece of graph paper and then cutting it out.
AJ Robinson
Re: Wireframe
on Dec 4, 2012 at 7:18:18 pm
Yeah thats what I was thinking. In that case, I'll just freeze the video and make a still of that frame. That should work out OK.
~AJ
