Text Layer Mask affected by Color Correction ...
COW Forums : Apple Motion
Paul Figgiani
on Nov 21, 2012 at 7:29:12 pm
Thanks for the help.
I have a text prompt that pops up in a published effect applied to a FCPX clip controlled by a checkbox widget. My problem is when I apply color correction to the clip - the text prompt is affected by the correction. For example if I test this with a heavy dose of green - the text turns green. It should remain solid gray.
The text layer resides in a Group by itself. I cloned the layer and added mask to it. I used the text layer as the Mask Source. Maybe I screwed something up in the Mask options? Regardless - I can't figure out how to keep the text on top of the video and have it unaffected by color correction/saturation/exposure adjustments.
Thanks again.
-paul.
Mark Spencer
Re: Text Layer Mask affected by Color Correction ...
on Nov 21, 2012 at 7:47:11 pm
Paul, make the text a Title effect rather than an -um- effect effect. That way it will be above the clip you are color correcting and therefore independent of the correction.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Paul Figgiani
on Nov 21, 2012 at 7:56:41 pm
Mark,
Thanks - but that's not what I'm trying to do. The display of the text - based on the check box setting is wrapped into an Effect. Are you saying that I can't have the text prompt be independent of the video as it would be in a Title?
Thanks again.
-paul.
Mark Spencer
on Nov 21, 2012 at 7:59:47 pm
I'm saying the color corrections are applied after effects, so they will impact any applied effects.
Mark Spencer
Paul Figgiani
on Nov 21, 2012 at 8:21:10 pm
Got it. Thanks again, Mark.
-paul.
