motion 5 keyframes not displaying correctly
COW Forums : Apple Motion
Alvaro Lanciai
on Oct 29, 2012 at 2:34:23 pm
Dear Friends,
I have a serious problem:
after painting with paintstroke I select the shape style light streak 3 and I need to adjust the COLOR OVER STROKE commands into the Keyframes editor...I have no way to see the animated KF in editor...
I just tried to (with the right track selected):
-right click over the COLOR OVER STROKE+choose "show in KF editor" (a new untitled set is created but I cannot see the animated KF)
-drag the same COLOR OVER STROKE to the KF editor (a new untitled set is created but I cannot see the animated KF)
-drag from timeline the paint stroke track (a new untitled set is created but I cannot see the animated KF)
-choose "animated" in the KF editor but I cannot see the Animated colorstroke KF
-I trashed all the preferences
-I disclose color over stroke triangle, I select one color and click on the color KF, choose "show in the KF editor" and it's working but I can see only that animated parameter in the KF editor but I need to see all the animated parameters in the same KF editors to adjust them correctly toghether...
With Motion 4.x I have only to click on the COLOR OVER STROKE and choose SHOW IN KF EDITOR and I can see and edit all the animated parameters perfectly...
Mark Spencer
Re: motion 5 keyframes not displaying correctly
on Oct 29, 2012 at 2:45:00 pm
Yes you have to edit them each separately now.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Alvaro Lanciai
on Oct 29, 2012 at 3:00:43 pm
dear Mark,
it's a tragedy...I receive some complex projects and I have to modify...I cannot know which parameters are involved in the animations...choose them end manipulate properly....
Once I get the right visualization about all animated parameters...maybe SHIFT-drag-and something else .... now I have only a track that is working properly...when I selected ANIMATED everything is showing right...
this demonstrate that it is possible to show the Animated KF..!
Alvaro Lanciai
on Oct 29, 2012 at 3:08:43 pm
Here's the screenshot
Mark Spencer
on Oct 29, 2012 at 3:10:00 pm
Good
Mark Spencer
Alvaro Lanciai
on Oct 29, 2012 at 3:13:25 pm
...I am not able to make it working on other tracks....
may be a bug...?
