Match move alternativ
COW Forums : Apple Motion
Jonas Bengtsson
on Oct 23, 2012 at 7:32:32 am
Match move i motion 5, works pretty ok fore our purposes, except one thing.
You can't run the application in the background.
As sone you switch to another application the match move analyzis stops.
Is it anny alternativ out ther?
Jonas Bengtsson
Re: Match move alternativ
on Oct 24, 2012 at 8:23:49 am
Happy today!
The tonights update of Motion 5, solved the problem.
Now you can run Match Move Analyze in the background
AJ Robinson
on Oct 24, 2012 at 3:21:13 pm
YES! Thanks Jonas!
~AJ
Chris Northcross
on Oct 24, 2012 at 7:37:29 pm
Yes, it would appear that the update has fixed that problem.
I had a couple of suggestions that I'd still like to share in the event that you ever need them: Mocha (which integrates pretty well with a Motion workflow, though it does require learning a new app) and Blender (which can be used as a finishing tool in place of Motion, though like Mocha it requires learning a new app and can be a rather steep learning curve.)
Mocha isn't cheap, but it has a planar tracker that is second to none. Blender is free! From what I understand, there is a way (plug-in I believe) that will allow you to send your results to Motion from Blender but I haven't used it. Both seem to be far more friendly at this point to After Effects.
But this may all be a moot point for you.
Happy tracking!
"Whether you think you can or can't, you're right."
Chris Northcross
on Oct 24, 2012 at 7:49:05 pm
Here's the link for the Blender - > Motion plug-in: http://forums.creativecow.net/thread/170/870306
Whether you believe that you can or you can't, you're absolutely right.
Ross Shain
on Oct 25, 2012 at 10:11:30 pm
Quite note on this... mocha AE v3 does support Apple Motion is relatively and is a very powerful application at an affordable price. You can learn more here: http://www.imagineersystems.com/products/mochaAE
Or check out these tutorials for mocha AE to Motion:
http://www.imagineersystems.com/videos?tagFilter=import+to+Apple+Motion&sor...
Best,
Ross
Ross Shain
Imagineer Systems
Ross Shain
on Oct 25, 2012 at 10:11:50 pm
Quick note on this... mocha AE v3 does support Apple Motion is relatively and is a very powerful application at an affordable price. You can learn more here: http://www.imagineersystems.com/products/mochaAE
Best,
Ross
Ross Shain
Imagineer Systems
