Enough for motion 4?
COW Forums : Apple Motion
Shaiful Reezal
on Oct 17, 2012 at 6:17:16 pm
Hi guys, i am very blur when it comes to specs and all. Recently, my motion 4 lags alot. Just wanna ask if this gotta do with the graphics card?
Or is there anything that i can do to make it fast again?
I am using a 21.5-inch, Mid 2011.
Chipset Model: AMD Radeon HD 6750M
Type: GPU
Bus: PCIe
PCIe Lane Width: x16
VRAM (Total): 512 MB
Vendor: ATI (0x1002)
Device ID: 0x6741
Revision ID: 0x0000
ROM Revision: 113-C2950H-175
EFI Driver Version: 01.00.560
AJ Robinson
Re: Enough for motion 4?
on Oct 17, 2012 at 6:49:18 pm
Your graphics card is pretty good- it's not the problem.
There are several things that could cause this problem.
(1) See how much hardrive do you have free?
(2) How much ram does you iMac have?
You mention that this problem is recent? You should try resetting the P-RAM. Do do this, click restart, then, when the screen turns white, quickly hit Command+Option+P+R. See full instructions here. Go to http://support.apple.com/kb/HT1379 then click on resetting PRAM/NRAM.
Hope I was helpful,
~AJ
Shaiful Reezal
on Oct 18, 2012 at 1:25:55 am
Hey! Thank you so much! Really appreciate ur help! Will try later and update u. Thanks!
AJ Robinson
on Oct 18, 2012 at 5:06:18 pm
Anytime!
Shaiful Reezal
on Oct 19, 2012 at 1:18:23 am
Hey Aj,
Your suggestion really works!!! I appreciate it... Thank you so much!! So if the lag comes again, can i keep doing what u suggested?
Shaiful
AJ Robinson
on Oct 19, 2012 at 3:48:18 pm
Yes, resetting the PRAM and the NRAM is a temporary fix, but it won't solve your problem permanently.
Good tips include: (1) Logging out of all other users (2) restarting your computer before and after using Motion (3) Try to keep as less programs open while using Motion (4) Upgrade your computer's hardrive & ram
One other thing if you are using Microsoft's Mac programs - Word, Powerpoint, Outlook- PLEASE quit all of those. They slow down the computer terribly. Virtual machines and other large programs (video editors (FCPX), 3D modelers etc.) also assist in slowing down the computer.
Hope I was helpful,
~AJ
