Changeable objects
COW Forums : Apple Motion
Schlanger Tamás
Changeable objects
on Sep 21, 2012 at 10:34:26 am
I was planning to change the shape of a rectangle (3d, using replication) to an other with a kind of leaking effect, but the possibilities to change the control points of a rectangle are quiet poor in keyframe editor.
Now I am looking for a possibility to "fill" the rectangle to inside an other using "preserve opacity", but I would need the second rectangle to be invisible but showing only the first rectangle inside.
Is it understandable?!
Thank You
Simon Ubsdell
Re: Changeable objects
on Sep 21, 2012 at 11:31:08 am
[Schlanger Tamás] "the possibilities to change the control points of a rectangle are quiet poor in keyframe editor"
Is your specific problem that you can't alter the keyframe interpolation?
Simon Ubsdell
http://www.tokyo-uk.com
Schlanger Tamás
on Sep 22, 2012 at 10:51:00 pm
Yes, I can not edit every single points of a rectangle.
And this is aggravated with a bug in Motion 5.0.3: when I change one or more points I get one single keyframe in keyframe editor (without value, determined only in time) but if I move (right-left) this keyframes it donesn't take effect at all, only if I delete all of them..
The described method what for I am waiting some help is just a secondary way.
I am stuck a bit..
Mark Spencer
on Sep 22, 2012 at 10:55:31 pm
That's not a bug, that's how keyframing control points works. It's an aggregate keyframe in that channel.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Schlanger Tamás
on Sep 23, 2012 at 9:43:23 am
I understand this aggregate keyframe concept.
The bug is I think that after taking some aggregate keyframes I can not change the result with moving this keyframes in time. So it seems the rectangle is not in connection with this aggregate keyframes.
Don't you have this experience?
