Where can i find an earth zoom tutorial for motion 5?
COW Forums : Apple Motion
Josh Fitzgerald
on Sep 7, 2012 at 10:28:47 am
Hi All,
Does anybody know where i can find an earth zoom tutorial for motion 5?
Ive found one for motion but its hard to follow...
Thankyou
Josh
AJ Robinson
Re: Where can i find an earth zoom tutorial for motion 5?
on Sep 7, 2012 at 1:50:25 pm
I see where you're coming from. He doesn't explain the layers very well. But, if you would do it step by step I'm sure you would be able to create the effect. Do exactly what he does then pause while your scaling and stuff. Then play it again and continue to go step by step.
I'll give you a little tip. Name all of your layers like closest, second closest, middle, second middle and so on and so forth. Then once you are done you can open up all the layers and see how it works!
You also look at a tutorial on how to do it in AE. I watch a lot of AE tutorials and just convert them to Motion!
I hope this tip helps!
AJ
Stephen Smith
on Sep 7, 2012 at 3:03:09 pm
First off, Google images are copyrighted. If you want to access them for commercial purposes you need to get Google Earth Pro and it is not cheap.
I love it how the tutorial keeps using Bring to Front. Why is he placing the image he wants on the top on the bottom and then bringing it to the front. Why not just bring them in the way you want them? I don't even understand why he is grouping things, if he used a camera instead he would not need to group anything. Plus I would add a Wiggle behavior at the start or end to get a little shake. I would feather the edges of the images to blend them in better.
For moves that are super long you want to use the Exponential or Logarithmic instead of Ease In. That will even out the Ease in so it doesn't feel like you are going super slow at the end of the move.
He said this is a copy cat tutorial. This is the original and much better: http://www.videocopilot.net/tutorials/earth_zoom/ Unfortunately for you it is an After Effects Tutorial. Fortunately for you the same concept applies to Motion other then the clouds, but the tutorial you posted covers that well.
Best of luck.
Stephen Smith
Utah Video Productions
Check out my Vimeo page
AJ Robinson
on Sep 8, 2012 at 5:36:28 pm
Ah thanks Stephen Smith!
Of course Cramer would have the awesome tutorial!
Stephen Smith
on Sep 10, 2012 at 3:05:25 pm
Happy to help.
Stephen Smith
Josh Fitzgerald
on Sep 12, 2012 at 11:54:18 am
Cheers guys.
Cracked on with it over the weekend. Slowly getting there.
Thanks for your help.
Josh
