Layers on/off with Rigs
COW Forums : Apple Motion
Univers Becker
on Sep 6, 2012 at 12:31:44 am
is there any way I could rig the on an off button of a layer. For Example: I got an animation effect layer like a text layer. With a check box it would be the easiest way to activate and deactivate such an effect.
thx. univers.
Anders Larsen
Re: Layers on/off with Rigs
on Sep 6, 2012 at 1:27:57 pm
I don't know if it can be done with a check box, but you can definately do it with a drop-down menu. Just make two states one with opacity 100% and one with opacity 0% and then use the drop-down to switch between them.
Mark Spencer
on Sep 6, 2012 at 1:32:36 pm
You can do it with any kind of widget - the key as Anders pointed out is that you use Opacity to "turn off' and "turn on" the layer(s).
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
