How do I fade?
COW Forums : Apple Motion
Tyler Jensen
How do I fade?
on Sep 4, 2012 at 8:59:28 pm
I don't know anything about motion. All I want to do is have a box highlight certain areas of a video. I have a box that comes in and leaves when I want it to. I just need it to fade in and out instead of just showing up and vanishing. This is Motion 5
Stephen Smith
Re: How do I fade?
on Sep 4, 2012 at 9:01:56 pm
The easiest way to do it is to use a behavior. Go to the Add Behavior icon. Go to Basic Motion, Fade in/Fade out.
Hope this helps best of luck.
Stephen Smith
Utah Video Productions
Check out my Vimeo page
Tyler Jensen
Re: How do I fade?
on Sep 4, 2012 at 9:15:20 pm
How do I add a behavior? I see behavior on the left but there are no options there. Thank You for the help
Stephen Smith
Re: How do I fade?
on Sep 4, 2012 at 9:55:10 pm
In Motion 5 Behaviors are applied to objects in one of the following ways:
Dragging a behavior to an object in the Canvas, Layers list, or Timeline
To apply a behavior to an object in the Timeline, drag the behavior to the object in the Timeline layers list or the Timeline track area.
Note: It is usually easier to drag a behavior to a camera or light in the Layers list or Timeline than to such objects in the Canvas.
Selecting an object, selecting a behavior in the Library, and then clicking the Apply button in the preview area
Selecting an object, and then choosing a behavior from the Add Behavior pop-up menu in the toolbar
Clicking the pop-up menu arrow at the right of a parameter's row in the Inspector, then choosing a Parameter behavior from the menu
Control-clicking a parameter of an object (including the parameters of other behaviors), and choosing a Parameter behavior from the shortcut menu
Stephen Smith
Tyler Jensen
Re: How do I fade?
on Sep 5, 2012 at 6:49:05 pm
That worked perfect. Thank you.
Stephen Smith
Re: How do I fade?
on Sep 5, 2012 at 7:37:42 pm
Happy to help and best of luck.
Stephen Smith
Richie Vitale
Re: How do I fade?
on Jan 10, 2017 at 6:42:51 am
There used to be a gear in Motion to add a behavior . . . is it still there? If so . . . I can't find it!
Mark Spencer
Re: How do I fade?
on Jan 10, 2017 at 2:28:56 pm
It's still there.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Richie Vitale
Re: How do I fade?
on Jan 10, 2017 at 7:29:33 pm
Don't see it . . . .
1 minute into the movie you posted, above the picture, on top of Motion . . . is a strip with a Behavior Gear in the center I'm missing.
Perhaps there?
I've attached 2 screenshots, one showing the strip missing and one the old gear that was easy to find and use and was open by default.
(Not sure how these embed codes work, I've been allowed to simply upload an image on other sites without inserting code.)
Mark Spencer
Re: How do I fade?
on Jan 10, 2017 at 7:47:00 pm
Mark Spencer
Richie Vitale
Re: How do I fade?
on Jan 10, 2017 at 7:51:22 pm
Richie Vitale
Re: How do I fade?
on Jan 10, 2017 at 9:33:45 pm
I restarted Motion while holding both the Option and Command keys at the same time, deleting my preferences, and the top menu is now showing along with the working Behavior Gear.
If anyone knows of a way to make the top menu appear and disappear, please let us know.
Many thx!
