Importing Images in Motion 5
COW Forums : Apple Motion
Deva Sunya
on Sep 3, 2012 at 1:25:19 am
Hi All...
I have a couple questions about importing images into Motion 5:
1- Is there any way to set the default length for an image when imported?
2- Is it possible to import a set of images so they are one after the other in the timeline instead of all layered on top of each other with their length the length of the project?
AJ Robinson
Re: Importing Images in Motion 5
on Sep 3, 2012 at 1:38:18 am
1. Yeah you can set a custom import duration. Go to prefs>project
Then set the default layer duration.
2. I don't know of any editor that can do that.
Deva Sunya
on Sep 3, 2012 at 2:20:12 am
Ahhh... thanks, that works for the image length. I saw layer length and did not think of it for images... much appreciated.
As for #2, FCP X you drag a group of images to the timeline and they are all in a linear sequence with each as long as the default setting. It is very easy.
AJ Robinson
on Sep 3, 2012 at 2:28:47 am
Ok that's cool
I was glad I could help,
AJ
Mark Spencer
on Sep 3, 2012 at 4:58:45 am
If the images are numbered sequentially, i.e, pict0001, pict002, etc., then you tell Motion to view them all as a single movie file by clicking the Show Image Sequences as Collapsed button at the bottom of the File Browser. You can then import this file like any other movie and it will play one image per frame.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Deva Sunya
on Sep 3, 2012 at 5:19:49 am
Thanks for the reply...
There is not much control over the way they play... no transitions etc... I suppose if the images are actually the frames of a movie that makes sense... anyway, appreciate your reply...
peter rudolfi
on Oct 20, 2014 at 11:06:40 pm
As far as "how the play" in n Image Sequence File, try in Properties/Timing/Frame Bending, changing that setting to Optical Flow. You're in for some fun.
Mark Spencer has an excellent tutorial here on Morphing:
