Fuzzy shapes
COW Forums : Apple Motion
Ben Dansby
Fuzzy shapes
on Sep 1, 2012 at 4:12:46 pm
Is there any way to make shapes conform to the pixel grid? All my squares are fuzzy. See zoomed in video here: https://dl.dropbox.com/u/3462104/edges.mov
Here are my project properties:
Andreas Zeitler
Re: Fuzzy shapes
on Sep 1, 2012 at 6:40:26 pm
I've been asking this question recently as well. It's driving me nuts. As far as I'm concerned there are no half-pixels.
Long story short: No answer yet. So not possible.
Ben Dansby
Re: Fuzzy shapes
on Sep 1, 2012 at 7:18:31 pm
Very frustrating indeed.
Simon Ubsdell
Re: Fuzzy shapes
on Sep 2, 2012 at 4:36:13 pm
As a workaround, try setting the Falloff of your Shape Fill to 1000.
This will crop off the semi-transparent antialiasing pixels.
You will however need to increase the dimensions of your shape slightly to compensate.
Also make sure that the shape position Transform isn't using fractions of a pixel.
Not a perfect solution but it might be of use to you.
Note that if you are using anything other than perfect squares or rectangles you will get stepping on any non-straight edges because you will have effectively turned off the anti-aliasing.
Simon Ubsdell
http://www.tokyo-uk.com
