Sharing MotionTemplates with other users and machines...
COW Forums : Apple Motion
Helge Tjelta
on Sep 1, 2012 at 2:51:25 pm
Since FCPX does only read motiontemplates from localusers home folder and inside movies only, here is the trick...:
Create a symbolic link to a shared location, NOT an alias, but symbolic link....
open terminal, do a cd to your movies folder
remove motion templates
and type in:
ln -s /Volumes/SharedDisk/folderForTemplates/ Motion Templates.localized
pay attention to .localized I had to put this on otherwise it would not do it.
Now open fcpx and it reads motiontemplates from the shared location.
(Thanks to Lars Petter for getting me on the right track)
cheers Helge Tjelta
Helge
Yarrow Sweningsen
Re: Sharing MotionTemplates with other users and machines...
on Apr 8, 2013 at 10:18:01 pm
Hi Helge, this is exactly what I am attempting to do, but can't duplicate from your instructions. Can you please check them carefully and make sure they are complete and exactly correct? Thanks!
Yarrow
Yarrow Sweningsen
on Apr 8, 2013 at 10:32:36 pm
I figured out the problem: I was not entering the path to the disk correctly. I dragged the Motion Templates folder into the Terminal window after typing ln -s and then got the correct path, which worked. Thanks!
William Davis
on May 20, 2013 at 7:27:13 pm
Greetings all-
I'm starting to test this on our Xsan environment as well. I'm curious to know what happens if more than one user is accessing the folder at the same time and someone generates new content (title, transition, filter, etc.)- do the other editors see this update live or do you only see it upon relaunching FCP? Also, what happens if more than one user is working from the same template at the same time?
Bill
Mark Spencer
on Jun 2, 2013 at 2:09:07 pm
Bill, what have you discovered?
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
William Davis
on Jun 3, 2013 at 9:08:28 pm
Hey Mark-
It seems to work, but it's risky. Since there's no server-side management of the files, there is always the possibility that another editor will open and modify a project that you are using in a project. This is a big hole in the workflow for FCP X editors working in a shared environment, and one that I hope Apple closes soon.
Bill
Mark Spencer
on Jun 4, 2013 at 3:52:37 pm
Agreed, Bill, thanks for posting back.
Mark Spencer
