Zooming on images becomes low res
COW Forums : Apple Motion
sean miller
on Aug 13, 2012 at 4:43:38 pm
I've got a series of drop zones scrolling across the screen that I originally put together in photoshop and brought into motion via importing the .psd as layers.
They start quite small, however the project calls for them to zoom in, then zoom back out, which I've done using the camera behaviours. The problem is that even though I'm using high res source files (that have been dropped into the drop zones) they're not scaling as the camera zooms in, rather I'm getting them at the resolution they appear before the zoom takes place - so all pixelated.
Is the is the right approach? I was wondering if perhaps using the grow behaviour may have different results instead of using the camera zoom?
Don Eitner
Re: Zooming on images becomes low res
on Aug 13, 2012 at 11:47:03 pm
I don't have any PSD files to try but it sounds like you might have the Fixed Resolution checkbox checked (on the group which contains the drop zone).
sean miller
on Aug 14, 2012 at 12:49:46 am
ah yes, christ... how did i miss that, thanks
