Can't see keyframes on text - unwanted /unexplained motion, in Motion 5
COW Forums : Apple Motion
Brian Jahns
on Aug 6, 2012 at 4:05:50 am
Just started using Motion 5, more of an after effects guy but I am designing a intro for a show based on a template (chosen by a producer.)
On some of the instances of text, I get a funky motion in the middle of the clip (scale and position change.)
The text had a behavior applied which I replaced with a different behavior (basic fade in/out.)
So my text fades in, is sitting there nicely when towards the end of the clip it doesn't this unwanted motion move.
I looked in the keyframe editor and there are no keyframes for position (or anything else.) I've tried removing behaviors and have also remade the text from scratch (was previously using text in template.) The fact that the issue still occurs after that last one really boggles my mind.
What is going on? I've restarted program and machine of course. My iMac actually does not meet the supposed 64 bit requirement but I feel that is probably not the cause.
2.66 ghz intel duo core, 4GB ram, mac OS 106.8, motion 5.0.3
