Motion 4 right on, masking issues
COW Forums : Apple Motion
César Ryugo
on Jul 27, 2012 at 6:32:31 pm
The idea is 2 lines that is a frame, I want it will showing up and then a picture comes up after suiting in the frame, so I imported the lines from Ai, and the picture in differents groups and use the paint stroke with right on behavior to make it show up. I did it to the first line, but when I did to de second one, the first line was gone when it was playing, and parts of picture that was hidden showed up.
So if anyone can help I really appreciate.
Stephen Smith
Re: Motion 4 right on, masking issues
on Jul 27, 2012 at 7:10:14 pm
With the paint stroke set to write on, I'm assuming that you have it set to a Luma blend mode. In motion the Luma blend mode effects everything. To get around it place the elements to write on (line and paint stroke) into their own group. Set the groups blend mode to Normal. Then it will not effect everything else in the project. Hope this makes sense and best of luck.
Stephen Smith
Utah Video Productions
Check out my Vimeo page
