Re: Motion4, Downsize 1280 x 1080 to 720 x 480
COW Forums : Apple Motion
Terry Lyons
on Jul 18, 2012 at 4:03:31 pm
I purchased a lower thirds template sized at 1280 x 1080. I need to export into a FCP movie that is 720 x 480.
If I change the Project Properties from the DVCPRO HD 1080p 30 Preset to NTSC DV, it will show as 720 x 480 under that General tab but then the animation disappears after I click OK. Same with NTSC Broadcast SD. If I export it as the QT Apple ProRes 422 at the native format of 1280 x 1080 then import into my FCP7 sequence of 720 x 480, the text becomes pixelated. How do I remedy this situation?
Terence Lyons
web/multimedia/photography
