Illustrator to Motion 5 script
COW Forums : Apple Motion
Marc Segarra
on Jul 9, 2012 at 5:33:28 pm
I was trying to open .Ai files in Motion 5.0.4, but it's impossible for me to load it with unfixed resolution, it loads the vectors as images.
I was looking for a Fixed resolution checkbox in Media, but it doesn't appear for me.
Otherwise, I read that exists a script to convert AI files from Illustrator to Motion, but the site is down because MobileMe it's no longer avialable.
http://www.motionsmarts.com/downloads.html
The file was called: il2motionshape.zip
And the script: Export as Motion shape.js
Someone can post the file or the zip? It will be helpful for the rest.
Thank you very much in advance.
Stephen Smith
Re: Illustrator to Motion 5 script
on Jul 9, 2012 at 7:25:47 pm
To change the "Fixed Aspect Ratio" do the following: Open up the Project Pane. Click on the Media tab. Select the AI file. Click on the Inspector tab in the Inspector. Select the Media tab if it is not already selected. Un check the Fixed Resolution check box. Jaggy edges become smooth.
Be sure your Illustrator file is RGB.
By the way, you can not work with the individual layers in a multi layered AI file in Motion. You can do it in AE. To work with multi layers you need to convert the AI to a PSD. Hope this helps and best of luck.
Stephen Smith
Utah Video Productions
Check out my Vimeo page
Marc Segarra
on Jul 9, 2012 at 7:42:50 pm
Stepeh,
Thank you very much for your answer.
Are you using Motion 4?
Because in my version, 5.0.4 it doesn't appear me the checkbox for disabling fixed resolution :(
You can see it here: http://img441.imageshack.us/img441/61/fixedresolution.png
I'm going crazy with this!
Thank you very much again!
Hope someone can help.
Marc Segarra
on Jul 9, 2012 at 7:47:40 pm
I've just found it.
Excuse me for all!
Thank you very much!!!!!!!!
Stephen Smith
on Jul 9, 2012 at 7:49:10 pm
Happy to help and best of luck.
Stephen Smith
