"Animate In" timing - title templates for Final Cut X
COW Forums : Apple Motion
Joel Larsen
on Jun 21, 2012 at 1:15:45 pm
Using: Motion 5 to create title templates (lower thirds) for Final Cut X
Issue I am running into is the length of the title.
Motion project is set to 20 seconds
Title (lower third) has a basic animation (fade and rotate) in that created in motion. When I use in Final Cut X everything works great, if I want the lower their to stay in for exactly 20 seconds. If I shorten or lengthen the title, the animation responds by animating very quickly or slowly.
Any suggestions as to how I can make my custom animation be an "animate in' option in Final Cut, so I can use the lower third at any length?
Mark Spencer
Re: "Animate In" timing - title templates for Final Cut X
on Jun 21, 2012 at 1:17:46 pm
You need to add Build In and Build Out markers in Motion to lock down the timing of the opening and closing animations.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Joel Larsen
on Jun 21, 2012 at 7:54:58 pm
Thanks so much for your time and input Mark! That is exactly what I was looking for.
I added a marker, then "edit marker" and make it a "build-in optional". Perfect.
Thanks again!
