Unable to change scale/pan of Effect Source in FCPX
COW Forums : Apple Motion
David Avraamides
on May 11, 2012 at 4:26:36 pm
I created a Final Cut Effect in Motion 5 that shows the cropped effect source next to a drop zone like below. I am using it to show a video clip (effect source) next to a photo (drop zone). The effect works well except for one problem. I am unable to adjust the scale and pan of the effect source. I've published those settings in Motion along with the scale and pan of the drop zone. The settings work for the drop zone but have no effect on the effect source in FCPX (they do work in Motion, however).
I'm new to Motion and FCPX (and video editing in general) so I'm guessing I'm overlooking something simple, but I can't see anything obvious that I've missed.
Does anyone have any suggestions for me to try and fix this?
-Dave
Mark Spencer
Re: Unable to change scale/pan of Effect Source in FCPX
on May 11, 2012 at 4:32:20 pm
Did you enable the Transform effect (button under the Viewer) and attempt to scale/position directly in the Viewer?
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
David Avraamides
on May 11, 2012 at 4:36:49 pm
That scales the entire screen (drop zone, effect source, borders, etc), not just the effect source. I want to "zoom in" on the video clip, not scale the whole effect.
Mark Spencer
on May 17, 2012 at 10:31:47 pm
David, this certainly should work, can you post the project?
Mark Spencer
