Motion 4, once stable, now stable as Charlie Sheen, crashes instantly at any action
COW Forums : Apple Motion
Mark Suszko
on May 9, 2012 at 8:51:53 pm
Motion 4, OS 10.6.8, quadcore intel xeon, 32GB 800 mhz RAM
This install was working well until some recent problems tied to an IO HD forced re-loading FCS 3.
Motion 4 will load, and you can drag assets into it and set up a nice effect. You can also open a template and play it on the timeline.
But it freezes for between 0 and 3 seconds, then hard-crashes (POP!), if you:
-Use the import dialog
-hit "save"
-hit "save as"
-hit "export"
-hit "render"
-blink your eyes.
Tried Motion 4 with all other apps off. No difference.
I've trashed the Motion 4 preferences, no appreciable change.
Ram checks out. Available hard drive space is around 30 gigs.
I ran Apple system monitor while Motion 4 was active. Nothing looked out of the ordinary; memory, i/o, all these looked optimal... except for some spikes of processor activity reaching over 100 percent, momentarily. These peaks did not always coincide with any action on the timeline; they would happen sometimes while sitting idle. if you do something that crashes the app, the crash happens too fast to see anything on the monitor program.
Please advise.
Mark Suszko
Re: Motion 4, once stable, now stable as Charlie Sheen, crashes instantly at any action
on May 10, 2012 at 2:26:56 pm
Copy-pasted from the top of the latest crash report:
Process: Motion [12839]
Path: /Applications/Motion.app/Contents/MacOS/Motion
Identifier: com.apple.motion
Version: 4.0.3 (729)
Build Info: Motion-7290000~62
Code Type: X86 (Native)
Parent Process: launchd [126]
Date/Time: 2012-05-10 09:20:07.880 -0500
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Interval Since Last Report: 84521 sec
Crashes Since Last Report: 11
Per-App Interval Since Last Report: 3746 sec
Per-App Crashes Since Last Report: 10
Anonymous UUID: 9F4AC480-AD70-42E3-A524-6703234DDD3F
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000026
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Application Specific Information:
objc_msgSend() selector name: frame
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 libobjc.A.dylib 0x9512e1bf objc_msgSend_stret + 15
1 ...le.prokit.SnowLeopardPanels 0x0b218e2a _NSProNavDrawLabelColorIndexImpl + 11395
2 ...le.prokit.SnowLeopardPanels 0x0b21766e _NSProNavDrawLabelColorIndexImpl + 5319
3 com.apple.ozone.framework 0x00ad7b2d -[OZDocumentController importAsDocument:] + 253
4 com.apple.AppKit 0x95631a26 -[NSApplication sendAction:to:from:] + 112
5 com.apple.prokit 0x001bd414 -[NSProApplication sendAction:to:from:] + 127
6 com.apple.AppKit 0x956318d9 -[NSMenuItem _corePerformAction] + 435
7 com.apple.AppKit 0x956315ca -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 174
8 com.apple.AppKit 0x956314b6 -[NSMenu performActionForItemAtIndex:] + 65
9 com.apple.AppKit 0x95631469 -[NSMenu _internalPerformActionForItemAtIndex:] + 50
10 com.apple.AppKit 0x956313cf -[NSMenuItem _internalPerformActionThroughMenuIfPossible] + 97
11 com.apple.AppKit 0x95631313 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 336
12 com.apple.AppKit 0x95625a55 NSSLMMenuEventHandler + 404
13 com.apple.HIToolbox 0x94668c2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
14 com.apple.HIToolbox 0x94667ef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
15 com.apple.HIToolbox 0x9468a7f3 SendEventToEventTarget + 52
16 com.apple.HIToolbox 0x946b6e87 SendHICommandEvent(unsigned long, HICommand const*, unsigned long, unsigned long, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 448
17 com.apple.HIToolbox 0x946dbb90 SendMenuCommandWithContextAndModifiers + 66
18 com.apple.HIToolbox 0x946dbb47 SendMenuItemSelectedEvent + 121
19 com.apple.HIToolbox 0x946dba5d FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 152
20 com.apple.HIToolbox 0x946ab160 MenuSelectCore(MenuData*, Point, double, unsigned long, OpaqueMenuRef**, unsigned short*) + 454
21 com.apple.HIToolbox 0x946aa8bb _HandleMenuSelection2 + 465
22 com.apple.HIToolbox 0x946aa6d9 _HandleMenuSelection + 53
23 com.apple.AppKit 0x9561ef96 _NSHandleCarbonMenuEvent + 285
24 com.apple.AppKit 0x955f3b46 _DPSNextEvent + 2304
25 com.apple.AppKit 0x955f2dd6 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 156
26 com.apple.AppKit 0x955b51f3 -[NSApplication run] + 821
27 com.apple.prokit 0x001c03f6 NSProApplicationMain + 326
28 com.apple.motion 0x000055de 0x1000 + 17886
29 com.apple.motion 0x00002746 0x1000 + 5958
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x93c97382 kevent + 10
1 libSystem.B.dylib 0x93c97a9c _dispatch_mgr_invoke + 215
2 libSystem.B.dylib 0x93c96f59 _dispatch_queue_invoke + 163
3 libSystem.B.dylib 0x93c96cfe _dispatch_worker_thread2 + 240
4 libSystem.B.dylib 0x93c96781 _pthread_wqthread + 390
5 libSystem.B.dylib 0x93c965c6 start_wqthread + 30
Thread 2: com.apple.CFSocket.private
0 libSystem.B.dylib 0x93c8fac6 select$DARWIN_EXTSN + 10
1 com.apple.CoreFoundation 0x93259c53 __CFSocketManager + 1091
2 libSystem.B.dylib 0x93c9e259 _pthread_start + 345
3 libSystem.B.dylib 0x93c9e0de thread_start + 34
Thread 3:
0 libSystem.B.dylib 0x93c70b5a semaphore_timedwait_signal_trap + 10
1 libSystem.B.dylib 0x93c9e6e1 _pthread_cond_wait + 1066
2 libSystem.B.dylib 0x93ccd5a8 pthread_cond_timedwait_relative_np + 47
3 ...ple.CoreServices.CarbonCore 0x9426cb90 TSWaitOnConditionTimedRelative + 242
4 ...ple.CoreServices.CarbonCore 0x9426c8ce TSWaitOnSemaphoreCommon + 511
5 ...ickTimeComponents.component 0x90fcb965 ReadSchedulerThreadEntryPoint + 4698
6 libSystem.B.dylib 0x93c9e259 _pthread_start + 345
7 libSystem.B.dylib 0x93c9e0de thread_start + 34
Thread 4:
5 ...ple.CoreServices.CarbonCore 0x942c75aa AIOFileThread(void*) + 1127
Thread 5: QTKit: QTSurfaceRendererScheduledDisplayThread
0 libSystem.B.dylib 0x93c70afa mach_msg_trap + 10
1 libSystem.B.dylib 0x93c71267 mach_msg + 68
2 com.apple.CoreFoundation 0x9321a2df __CFRunLoopRun + 2079
3 com.apple.CoreFoundation 0x932193c4 CFRunLoopRunSpecific + 452
4 com.apple.CoreFoundation 0x9321f304 CFRunLoopRun + 84
5 com.apple.QTKit 0x902ff226 QTSurfaceRendererScheduledDisplayThread + 164
Thread 6: QTKit: QTVisualContextImageProviderWorkLoop
5 com.apple.QTKit 0x902fb465 QTVisualContextImageProviderWorkLoop + 128
Thread 7:
5 ...ple.CoreServices.CarbonCore 0x94290b8b TimerThread + 97
Thread 8:
5 ...ple.CoreServices.CarbonCore 0x94300092 DeferredTaskThread + 84
Thread 9:
5 com.apple.QuickTime 0x93e9bdab VideoDecodeThread + 83
Thread 10:
5 com.apple.DVCPROHDMuxer 0x3a12498f AVS::DestroyAVCDeviceController(AVS::AVCDeviceController*) + 317
Thread 11:
0 libSystem.B.dylib 0x93c9eaa2 __semwait_signal + 10
1 libSystem.B.dylib 0x93c9e75e _pthread_cond_wait + 1191
2 libSystem.B.dylib 0x93ca03f8 pthread_cond_wait$UNIX2003 + 73
3 com.apple.ozone.framework 0x00a2bddb OZExecutionUnit::executeLoop() + 75
4 com.apple.ozone.framework 0x00a2bede OZExecutionUnit::executeLoopWrapper(void*) + 94
5 com.apple.procore.framework 0x019cc0a8 PCThread::startup(void*) + 18
Thread 12:
Thread 13:
Thread 14:
Thread 15:
Thread 16: QTKit: QTSurfaceRendererScheduledDisplayThread
Thread 17: QTKit: QTVisualContextImageProviderWorkLoop
Thread 18: QTKit: QTSurfaceRendererScheduledDisplayThread
Thread 19: QTKit: QTVisualContextImageProviderWorkLoop
Thread 20: Dispatch queue: TFSVolumeInfo::GetSyncGCDQueue
1 libSystem.B.dylib 0x93cca9c5 nanosleep$UNIX2003 + 188
2 libSystem.B.dylib 0x93cca903 usleep$UNIX2003 + 61
3 com.apple.DesktopServices 0x9a69c731 TNode::WaitToBeSynced(bool) + 197
4 com.apple.DesktopServices 0x9a69c4a0 TNode::StSynchronize::StSynchronize(TNodePtr const&, unsigned long) + 210
5 com.apple.DesktopServices 0x9a6ead2a TNode::GetNodeFromPathName(TUString const&, TNodePtr&) + 76
6 com.apple.DesktopServices 0x9a6a62a9 TNode::FindUserFolder(unsigned long, bool, TNodePtr&) + 229
7 com.apple.DesktopServices 0x9a6a60a4 TNode::SetSpecialNodeFromOStype(unsigned long) + 142
8 com.apple.DesktopServices 0x9a6a5f7c TNode::SetSpecialNode(unsigned long, TNodePtr&) + 276
9 com.apple.DesktopServices 0x9a6a0683 TNode::GetSpecialNodeWithStatus(unsigned long, OpaqueNodeRequest* const&, unsigned long, TNodePtr&) + 617
10 com.apple.DesktopServices 0x9a6b7166 TNode::GetSpecialNode(unsigned long, OpaqueNodeRequest* const&, unsigned long) + 50
11 com.apple.DesktopServices 0x9a6b70de TNode::IsDesktop() const + 98
12 com.apple.DesktopServices 0x9a6b6a52 TNode::ResolveSharedFileListAliasIfNeeded() + 756
13 com.apple.DesktopServices 0x9a69e22b TNode::SynchronizeChildren(unsigned long, TNodeEventPtrSet&) + 4409
14 com.apple.DesktopServices 0x9a69cc08 TNode::HandleSync(unsigned long) + 886
15 com.apple.DesktopServices 0x9a69c85e TNode::HandleSync(TCountedPtr const&, TNodePtr const&) + 56
16 com.apple.DesktopServices 0x9a6ef4ea TNode::HandleNodeRequest(TCountedPtr const&, TCountedPtr const&) + 1154
17 com.apple.DesktopServices 0x9a69acbd __PostNodeTaskRequest_block_invoke_2 + 94
18 libSystem.B.dylib 0x93ca4a24 _dispatch_call_block_and_release + 16
19 libSystem.B.dylib 0x93c9748c _dispatch_queue_drain + 249
20 libSystem.B.dylib 0x93c96ee8 _dispatch_queue_invoke + 50
21 libSystem.B.dylib 0x93c96cfe _dispatch_worker_thread2 + 240
22 libSystem.B.dylib 0x93c96781 _pthread_wqthread + 390
23 libSystem.B.dylib 0x93c965c6 start_wqthread + 30
Thread 21:
3 com.apple.AppKit 0x9575ce2d -[NSUIHeartBeat _heartBeatThread:] + 2039
4 com.apple.Foundation 0x94e5d4c4 -[NSThread main] + 45
5 com.apple.Foundation 0x94e5d474 __NSThread__main__ + 1499
Thread 22:
4 com.apple.CoreFoundation 0x932191f1 CFRunLoopRunInMode + 97
5 com.apple.Foundation 0x94e96224 +[NSURLConnection(NSURLConnectionReallyInternal) _resourceLoadLoop:] + 329
6 com.apple.Foundation 0x94e5d4c4 -[NSThread main] + 45
7 com.apple.Foundation 0x94e5d474 __NSThread__main__ + 1499
8 libSystem.B.dylib 0x93c9e259 _pthread_start + 345
9 libSystem.B.dylib 0x93c9e0de thread_start + 34
Thread 23:
5 com.apple.DesktopServices 0x9a692b3d TSystemNotificationTask::SystemNotificationTaskProc(void*) + 643
6 ...ple.CoreServices.CarbonCore 0x9424c54a PrivateMPEntryPoint + 68
7 libSystem.B.dylib 0x93c9e259 _pthread_start + 345
8 libSystem.B.dylib 0x93c9e0de thread_start + 34
Thread 24: Dispatch queue: TFSVolumeInfo::GetSyncGCDQueue
0 libSystem.B.dylib 0x93c7b8da __getdirentries64 + 10
1 libSystem.B.dylib 0x93c7b879 _readdir_unlocked$INODE64 + 78
2 libSystem.B.dylib 0x93c7b814 readdir$INODE64 + 70
3 com.apple.CoreFoundation 0x931ed171 _CFBundleCopyDirectoryContentsAtPath + 1793
4 com.apple.CoreFoundation 0x931f9921 _CFBundleCopyInfoDictionaryInDirectoryWithVersion + 1169
5 com.apple.CoreFoundation 0x9325cf4e _CFBundleCopyInfoDictionaryInDirectory + 286
6 com.apple.CoreFoundation 0x9325cdf0 CFBundleCopyInfoDictionaryForURL + 80
7 com.apple.LaunchServices 0x9a2b2b0c FSNodePrepareBundleInfoDictionary + 82
8 com.apple.LaunchServices 0x9a2a696a _LSCopyNodeAttribute_DisplayNameIfDifferentFromFSName(LSNodeAttributeStateCache*) + 416
9 com.apple.LaunchServices 0x9a2a6791 _LSCopyNodeAttribute_DisplayName(LSNodeAttributeStateCache*) + 29
10 com.apple.LaunchServices 0x9a2a62ca _LSCopyNodeAttribute + 174
11 com.apple.LaunchServices 0x9a2a59e2 _LSCopyItemAttributeForRefInfoWithOptions + 281
12 com.apple.LaunchServices 0x9a2a58c3 _LSCopyDisplayNameForRefInfo + 59
13 com.apple.DesktopServices 0x9a6a2139 TFSInfo::GetDisplayName() const + 257
14 com.apple.DesktopServices 0x9a6a6da1 TNode::GetDisplayName(TUString&) const + 259
15 com.apple.DesktopServices 0x9a6b6a98 TNode::ResolveSharedFileListAliasIfNeeded() + 826
16 com.apple.DesktopServices 0x9a69e22b TNode::SynchronizeChildren(unsigned long, TNodeEventPtrSet&) + 4409
17 com.apple.DesktopServices 0x9a69cc08 TNode::HandleSync(unsigned long) + 886
18 com.apple.DesktopServices 0x9a69c85e TNode::HandleSync(TCountedPtr const&, TNodePtr const&) + 56
19 com.apple.DesktopServices 0x9a6ef4ea TNode::HandleNodeRequest(TCountedPtr const&, TCountedPtr const&) + 1154
20 com.apple.DesktopServices 0x9a69acbd __PostNodeTaskRequest_block_invoke_2 + 94
21 libSystem.B.dylib 0x93ca4a24 _dispatch_call_block_and_release + 16
22 libSystem.B.dylib 0x93c9748c _dispatch_queue_drain + 249
23 libSystem.B.dylib 0x93c96ee8 _dispatch_queue_invoke + 50
24 libSystem.B.dylib 0x93c96cfe _dispatch_worker_thread2 + 240
25 libSystem.B.dylib 0x93c96781 _pthread_wqthread + 390
26 libSystem.B.dylib 0x93c965c6 start_wqthread + 30
Thread 25: Dispatch queue: TFSVolumeInfo::GetSyncGCDQueue
2 libSystem.B.dylib 0x93c71100 mach_port_deallocate + 127
3 libSystem.B.dylib 0x93ccb551 mach_msg_destroy_port + 233
4 libSystem.B.dylib 0x93ccb3a9 mach_msg_destroy + 36
5 com.apple.CoreFoundation 0x93241af8 CFRunLoopWakeUp + 216
6 com.apple.DesktopServices 0x9a6a98bd TNotifier::Tickle(bool) + 363
7 com.apple.DesktopServices 0x9a6a9635 TNodeEvent::RedispatchEventToNotifier(unsigned long, OpaqueEventQueue*, TCountedPtr const&) const + 225
8 com.apple.DesktopServices 0x9a699d35 TNodeEvent::Notify(TNotifierList const&) + 243
9 com.apple.DesktopServices 0x9a699673 TNode::SendNotification(unsigned long, TNodePtr const&, unsigned long, long) const + 605
10 com.apple.DesktopServices 0x9a6a1670 TNode::SetAliasTarget(TNodePtr const&, bool) + 406
11 com.apple.DesktopServices 0x9a6b6a47 TNode::ResolveSharedFileListAliasIfNeeded() + 745
12 com.apple.DesktopServices 0x9a69e22b TNode::SynchronizeChildren(unsigned long, TNodeEventPtrSet&) + 4409
13 com.apple.DesktopServices 0x9a69cc08 TNode::HandleSync(unsigned long) + 886
14 com.apple.DesktopServices 0x9a69c85e TNode::HandleSync(TCountedPtr const&, TNodePtr const&) + 56
15 com.apple.DesktopServices 0x9a6ef4ea TNode::HandleNodeRequest(TCountedPtr const&, TCountedPtr const&) + 1154
16 com.apple.DesktopServices 0x9a69acbd __PostNodeTaskRequest_block_invoke_2 + 94
17 libSystem.B.dylib 0x93ca4a24 _dispatch_call_block_and_release + 16
18 libSystem.B.dylib 0x93c9748c _dispatch_queue_drain + 249
19 libSystem.B.dylib 0x93c96ee8 _dispatch_queue_invoke + 50
20 libSystem.B.dylib 0x93c96cfe _dispatch_worker_thread2 + 240
21 libSystem.B.dylib 0x93c96781 _pthread_wqthread + 390
22 libSystem.B.dylib 0x93c965c6 start_wqthread + 30
Thread 26:
0 libSystem.B.dylib 0x93c96412 __workq_kernreturn + 10
1 libSystem.B.dylib 0x93c969a8 _pthread_wqthread + 941
Thread 27: Dispatch queue: TFSVolumeInfo::GetSyncGCDQueue
0 libSystem.B.dylib 0x93caba5a recvfrom$NOCANCEL$UNIX2003 + 10
1 libSystem.B.dylib 0x93caba4b recv$NOCANCEL$UNIX2003 + 54
2 libSystem.B.dylib 0x93cab9df read_all + 41
3 libSystem.B.dylib 0x93cab7f3 deliver_request + 886
4 libSystem.B.dylib 0x93ccdf8e DNSServiceEnumerateDomains + 224
5 com.apple.CFNetwork 0x96fc432b CFNetServiceBrowserSearchForDomains + 291
6 ...ple.CoreServices.OSServices 0x97ef62a9 DomainBrowser::scheduleBrowser() + 143
7 ...ple.CoreServices.OSServices 0x97ef611b DomainBrowser::start() + 63
8 ...ple.CoreServices.OSServices 0x97ef5fa2 NodeBrowser::loadDomains() + 182
9 ...ple.CoreServices.OSServices 0x97ef3dc8 NodeBrowser::takeAction() + 208
10 libSystem.B.dylib 0x93ca5498 _dispatch_source_latch_and_call + 62
11 libSystem.B.dylib 0x93c983d2 _dispatch_source_invoke + 210
12 libSystem.B.dylib 0x93c96f59 _dispatch_queue_invoke + 163
13 libSystem.B.dylib 0x93c97495 _dispatch_queue_drain + 258
14 libSystem.B.dylib 0x93c96ee8 _dispatch_queue_invoke + 50
15 libSystem.B.dylib 0x93c96cfe _dispatch_worker_thread2 + 240
16 libSystem.B.dylib 0x93c96781 _pthread_wqthread + 390
17 libSystem.B.dylib 0x93c965c6 start_wqthread + 30
Thread 28:
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x025ad900 ebx: 0x0b216e0a ecx: 0x95d9ba7c edx: 0x00000006
edi: 0x00000000 esi: 0x95d9ba7c ebp: 0xbfffe738 esp: 0xbfffe6c8
ss: 0x0000001f efl: 0x00010206 eip: 0x9512e1bf cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0x00000026
Rodney Higgins
on May 21, 2012 at 8:12:05 pm
We've been experiencing the same issue with this for several weeks. Seems like any time we do anything in Motion that invokes a dialog window, such as "Save As" or "export" or even trying to change the path of the Motion Library & Templates, causes the exact type of crashes you describe.
We're on a SAN System, & just recently upgraded from OS 10.5.x to OS 10.6.8. Doesn't seem that our engineers did a "clean" install, or updated the Final Cut Studio apps. I'll be checking in to see if anyone has any suggestions.
"It's only television; nobody dies."
Mark Suszko
on May 21, 2012 at 10:28:27 pm
Well, our "fix" turned out to be a replacement hard drive and a re-load of every. gorram. program. @ weeks later, I'm still re-loading the odd plug-in and whatnot.
But it's running right now.
This time, once stable and complete we WILL image the drive as I had suggested to them before.
