Changing Serial Number
COW Forums : Apple Motion
Praveen Nu
on May 9, 2012 at 7:51:26 pm
I have 2 Apple Motion 4 licences. But i installed Motion on two systems with the same serial number. Now i want to change the serial number of one. Is there a way to change it without re-reinstalling the Motion?
Praveen
http://www.nupraveen.com
Chris Lehmann
Re: Changing Serial Number
on May 11, 2012 at 1:54:51 pm
/Library/Application Support/ProApps/Final Cut Pro System ID
I believe if you delete this file a prompt to enter the serial number will pop up next time you open any of the FCPS apps. Worked for me moving a personal license to a work license.
Praveen Nu
on May 11, 2012 at 2:06:14 pm
Got it!! Library/Application Support/ProApps and remove the FCS System ID file. The next time you launch one of the ProApps, it will ask for the serial number. At that point, enter the new serial number
